Hi everyone,
I often work with sheet metal parts containing many holes. When I select multiple hole edges (using Ctrl + Shift) and want to remove/deselect a specific subset of those holes, I run into trouble:
Using
Ctrl+ selection window (left-to-right or right-to-left) either does nothing or clears the entire selection because of the double edge / solid thickness geometry. -
Ctrl + Shiftonly adds to the selection, it doesn’t subtract.
Is there a native way, macro, or workaround to cleanly deselect a specific group of sub-object edges from an active multi-selection without losing everything?
Thanks in advance for any tips!
