I’m new to Rhino but proficient in Sketchup and AutoCAD. I’ve decided to build a stair case as a test using only Rhino. I’ve drawn all my objects as curves then extruded and used Boolean operations as necessary.
In the case of the spindels, I drew a profile then rotated. At any rate, I’m now stuck. I’d like to stretch the upper half of the spindle from the top cap to reach the hand rail line, The stretch should take place between the top cap and and the next isocurve above the turned detail. This is a 1 second thing in Sketchup. I can’t figure out how to do it in Rhino.
Hi CalypsoArt - the Stretch command may help here - you can set a start and and point for the area to be stretched, but, even better would be to plan ahead a little and use History:
Make the top part of the post from a revolve with History.
Copy the result to all the locations, again with History.
Modify - point edit - the curve for the orignal revolved post - pull the top point a little higher - and the others will update.
Now, in this case that History connection will be broken if you cut the square base of the post from the original revolve, so make the top bit separately.
Using blocks might be useful here as well, with the repeated elements. http://wiki.mcneel.com/rhino/usingblocks
Thanks for pointing out that command. However, it does not give the result I want with this object. I’m only stretching a couple inches, but the shape changes in more than just in length. Looking at the spindle on the left, I would have thought the stretch would only take place between the top and next isocurve down. The right spindle is what I get.
Hi @CalypsoArt, when I first started Rhino I found once I got my head around degree, control points and knots I could modify objects more purposefuly. Page 135 of the manual has a really good explanation of how these effect editing.
If it was me trying to do what you want I would use cage edit with enough points on the vertical to isolate the region you want to edit leaving the rest unchanged…but there is pobably a better way to do this that someone else can provide. HTH
Is the upper part tapered or parallel/cylindrical? I suspect it is tapered hence the extra isolines after a stretch.
Perhaps a better way is to model the longer version and trim to the shorter height. This will keep everything identical except the top bit of the long versions. As it is, if the upper parts are tapered, the upper parts would not be identical after the stretch.
