I’m really a beginner in Grasshopper and I’m struggling a lot with achieving the goal I want.
Following issue I can’t manage to work is to split up the dome, so I have a serie of 36 arms, in order to be able to adjust every segment of the structure by a curve.
Also I would like to split up every segment (two wings) of every arm, so they can also open and close separately.
Thank you for your help. I maybe didn’t explain it well in my description. But I would like to have every arm separately in orde to change the shape of the dome, by adjusting the curve.
After that, I would indeed like to transform the initial curve for every arm by a rule, so that the dome could change into other shapes.
I’m not sure if the way I started drawing the dome is the best way to achieve what I want.
Mainly the concept is a ‘smart roof’ for an existing structure. The concept is shown in the image below: But now I would like to be able to make for example asymmetrical shapes.
It’s a schoolproject, but I managed to get myself to be the only student working for the first time working with Grasshopper/Rhino…
