I had this problem once before, but can’t remember the solution.
I’m using Neon and need to specify various output image sizes.
Hyphen should help: -ViewCaptureToFile
You will find options in command prompt.
HTH
Yeah that’s it thanks. What is it with this magic Hyphen? gonna try it out all over the place…
Do you happen to know a way to specify (realtime) viewport size as well? (so I can watch the Neon pass count and pretend to be working…)
C
The hyphen is to force Rhino to put all command options on the command line. Normally this is used to supress dialog boxes, but in cases like this it shows options on the command line that you wouldn’t see otherwise.
see also: help file
