I’m trying to automatically transform an object using BoxEdit.
I have rs.Command("_SelAll _BoxEdit") however I would like to specify the values for the Rotation. It doesn’t work when I do this.
Is there any way to pass in values for menu items to rs.Command?
Hi @Shawn_Broukhim,
unfortunately _BoxEdit cannot be filled with values from the command line or via rs.Command. Since you’re running a script already, why not use rs.ScaleObjects ?
import Rhino
def DoSomething():
objs = rs.AllObjects(select=True)
if not objs: return
origin = Rhino.Geometry.Plane.WorldXY.Origin
xyz_scale = (2.0,2.0,2.0)
rs.ScaleObjects(objs, origin, xyz_scale, copy=False)
DoSomething()
c.
