I’m trying to blend these surfaces. After unchecking the ‘show isocurves’ box, there is still a visible jagged edge. Is there a way to smooth or reduce the number of isocurves to avoid a bumpy surface?
Hi Annamlis,
try to use “add shapes” while using the blend surface command. Pick opposite points which are close to each other to force a nicer blend.
Great thanks it worked!
