How to simulate computer screen
I’m trying to create a model of a computer screen that is turned on. The screen image is supposed to be sharp and bright against the dark surrounding (since a real screen emits light so the screen is visible and it lights up its surroundings), but it’s also supposed to show the screen contents. The screen content is a decal at the moment.
No matter what I try, I cannot get the right result; in the attached sample model, there are 2 Screen layers (only one of them is supposed to be visible at a time) - one is the screen only with the decal and the other two are the screen with the decal and an emission material (33% and 100%, respectively). The screen surface is set to not receive shadows.
If I try to render with just the decal (no emission), the screen is dark (as expected). If I render with the decal + 33% emission, the decal is washed out by the emission light. Using the 100% emission variant the decal becomes completely invisible, as the screen becomes a light.
Is there a better approach to get the effect I’m going for or is this something that I can only do in Photoshop after rendering?
Here’s a sample picture that shows roughly what I’m after (screen content visible in dark room and casts light on surroundings):
Here’s a picture of what I do NOT want:
Here’s my sample model:
emission-issue.7z (205.3 KB)
Any advice would be appreciated.
Don’t use the ‘decal’ feature, use a texture in the emissive material. “Decals” are literally just for things that are supposed to look like decals…
@JimCarruthers I didn’t think of that, thank you, but how do I do that? When I open the emission material, it has no texture option. Should I use Blend with an emission and the picture with the decal as the texture?
Edit:
Thank you for the idea, I managed to do this:
Is there a better option? This is a big step forward, self-illumination makes it much better, but it doesn’t illuminate the surroundings. When I use the emission color option, that washes the image out again.
Hi Gyorgi,
Use a PBR material with the blue screen image applied as a texture to the emission property. Up the intensity to, say, 1.6. Also, set the Base Color to black to avoid washing out the image.
HTH
Jeremy
Awesome advice, thank you! I had no idea this was possible. I’ve been wrangling with this for a while now, here’s how my final scene looks like:
Hi @gyorgy.bozoki ,
I’ve also added an enhancement request for the Emission material to have a texture option. https://mcneel.myjetbrains.com/youtrack/issue/RH-90933
Thank you @BrianJ for adding this. I have long wondered why that was not possible.
@BrianJ Thank you, that would indeed be very useful.
Note that the emission material is just a simple interface to the physically based material. For more control after adding emission material change the material type from emission material to physically based. You can then add the texture.
