V5
I have a jpg I need to use and have found its name on a PictureFrame in ‘materials’ tab, so its in ‘here somewhere’ ! and need to find its layer then view layer and work on it.
How is this done ?
I cant see anything in right click list on the PictureFrame to say show layer or open and select item.
select the the object then right click in the layer, something similar to this should show up. or are you not seeing the picture frame at all? not sure how to understand your description.
oops didnt spot that, try it and if the image exists, and if the layers are unlocked, then the hammer and ‘show object layer’ works.
I try another file and most see nothing happen, its one of those thats brought in loads of ‘materials’ which dont actually exist when searched on. OMG what a system !
I see a yellow line appear but zoom all viewports does nothing.
So unlock all layers, then right click and select object, then hammer and ‘show object layer’ and zoom all viewports icon, if the PictureFrame is not a red herring !
