How to Show/Hide Context Geometry?
I know the “stream filter” works for options. But what I am trying to do is to show/hide a surface that would cut a building.(The red plane in the image below) It is not an option, it is just a plane which is the limit one can build to for this building(setbacks), and I would like to have the option for someone to show and hide it. It is just a simple surface parameter in grasshopper. Normally MetaHopper has a tool for that, which is not supported by ShapeDiver.
Any other solutions?
The best way to show and hide objects is with a stream filter using toggle instead of drop-down menu. Users can then simply switch objects on and off.
