Hi
I searched for how to change the default setting in the print footer (filename) but no luck finding any hints.
Every time I start Rhino and want to print a pdf, the text is not proper. Is it possible to change that to setting the Text? Its just a bit annoying since I want to show the address of rhino file…
Thank you in advance
Hi -
I’m not sure if I’m understanding this correctly. The Filename
print option is a document property. If you want to have this turned on for all of your new files, you’ll have to change that in the template that you use for new files.
Hi Wim
Thank you for your advice
Rgds,
Ziustiar
