How to set the working plane to the view top?
How to set the working plane to the view and in front of all objects in Rhino?
What is the quick way to sketch on top of all objects without drawing behind them when the default setting is to work plane to view?
use the command Cplane then option View that will set the cplane to the current view. for the Cplane you have in your display modes under grid the option to set above objects, be aware that this is valid for each display mode individually, so you might have to set it for all display modes.
Hello, in practice, there are no other options except setting the view as the working plane. Drawing on this working plane is uncontrollable and easy to draw behind the existing model.
