How to set the draw order in Rhino Common
Is there a way to set the draw order on an entity when using rhino common?
So it would be like using the Rhino commands Sendtoback or Bringtofront, but in code.
I have looked at dp.SetZBiasMode(ZBM_TOWARDS_CAMERA)
but don’t understand how to use it, and was hoping for something simpler.
The best you can do is script the commands using RhinoApp.RunScript.
– Dale
Yes, I can see how to do that with RunScript. But I was hoping for something a bit more integrated.
To change an entities color we use code like:
          obj = doc.Objects.Find(object_uuid)
          obj.Attributes.ObjectColor = mycolor
          obj.Attributes.ColorSource = DocObjects.ObjectColorSource.ColorFromObject
          obj.CommitChanges()
Is there anything like this that we can do to send the entity to the front or back of the draw order?
Hi @andrew3, only if you know the display index of all objects in the doc. You might try
obj.Attributes.DisplayOrder
_
c.
Thanks, that worked OK.
For reference I used :
obj.Attributes.DisplayOrder = -1
to send the “old” object to the back.
