Everything in the title
How to set the color of boundery surface using the point color if the point is inside the boundery surface ?
What is point color? You mean converting point’s XYZ coordinates to color RGB values?
No, it really is not.
assuming the referenced point in Rhino has a color assigned, (like it’s display color property), you would first need to get that info. You could do it with a fairly straightforward ghpython component, (set type hint for input x to GUID).
import Rhino
obj = Rhino.RhinoDoc.ActiveDoc.Objects.Find(x)
print obj.Attributes.ObjectColor
a = obj.Attributes.ObjectColor
from there, you would then perform your point inclusion test with standard GH components. If it’s on/in the surface, color the surface with the point color, if not…do something else.
