How to set Rhino template when exporting CAD data from SD export download
We would like the downloaded file to open with an already existing user created template or set the render settings for the exported file.
Would anyone be able to help with this issue?
It is not possible to use a predefined template for exporting, but you set a lot of properties for the exported objects using the Export Attributes and Export Options components, such as names, layers, plot colors, etc… depending on the properties supported by the format you are using.
