How to set object opacity in ghosted mode
When using the _SetObjectDisplayMode command, one can set the ghosted mode but there’s no option to set opacity.
Is there an option to set it per object?
If not could I make a feature request to add that?
Thanks.
UPDATE:
Secondary request, is there maybe possibility to add Ghosted mode per layer?
Hi @ivelin.peychev,
opacity is set via the ghosted display mode then. To get individual opacity per object, you would need to use a material and assign a display mode which shows objects with their render material.
_
c.
so individual objects must be set to rendered mode with the proper material, while the viewport is, e.g. wireframe?
But won’t that worsen the performance?
Yes, use _SetObjectDisplayMode=Rendered and make sure to assign the render material having the desired opacity.
I think it will not be slower compared to regular Rendered display mode. You also do not have shadows in Wireframe display mode.
_
c.
Thanks @clement !
