I created a distorted rectangle shape with LOFT.
But Rhino.Inside doesn’t work with face to define the wall, it only works with Curve and Profile but doesn’t accept the distorted geometry.
Have a solution?
Please.
Thanks.
Have a solution?
Please.
Thanks.
See this thread for the latest on Wall by Face available in Rhino.Inside.Revit
But this thread shows that it’s the Revit mass, it’s different.
I want to define what was created in GH, understand?
You can not achieve that kind of wall geometry through the normal wall command in Revit, thus it is the same through RiR. And since, the way to accomplish it inside Revit is using the mass tool and wall by Face, you would automate that same process through RiR as Japhy mentioned above.
If you have something else in mind let us know.
