Hello is there a way to sellect geometry that are using or not using layer material? if not is it scriptable?
I want to sellect objects that are using object based material directly given to them by vray not their layers.
Thank you.
Thank you.
Maybe you can use SelMaterialName to find objects with a specific material name.
It pops up a list of materials defined in the file.
I can do that manually from vray asset editor smilar to rhino material panel but there are way too much material.
This helps: https://developer.rhino3d.com/api/rhinoscript/selection_methods/objectsbymaterialsource.htm
Create a new script with this:
_-runscript (
sub SelectObjectsWithLayerMaterial
Rhino.UnselectAllObjects ()
Rhino.ObjectsByMaterialSource (0) ,True
End sub
