How to select every nth subbranch?
Below is my solution, but I hope there is a simpler way to do it. Selecting every second subbranch requires editing the dispatch pattern.
2024-04-09_subbranch.gh (14.3 KB)
I use these tools foradditional Tree manipulations:
There is absolutely no need for a plugin to do what @feklee wants to do :bangbang: And there are other standard components besides Dispatch for culling.
Hi @feklee ,
Is this what you are after?
Graph Space:
You can use Split Tree with a wildcard (asterik) mask at the start of the mask pattern, then the value of 0 following that will return the 0 index value at each “primary” branch.
Sometimes I use Concatenate to make a “parametric” masking pattern if I want to iterate a little more quickly.
If that is not what you are after can you please type what the expected result is?
Hope that helps, thanks!
20240409_subbranch_Response_01a.gh (12.9 KB)
That! Thank you!
Much simpler now:
2024-04-10_subbranch.gh (10.1 KB)
You’re welcome!
