Sometimes I just wish to create emty openings inside walls.
I archive this by deleting the frame/leaf from the window object, hoever ater that I am unable to select the opening anymore…
Any advice?
thanks
Andreas
Any advice?
thanks
Andreas
Hi Andreas, take a look at this Topic: VisualArq Extract Solids Selection
I’ve added an opening style (with a rectangular profile) that you can select through some auxiliary curves.
thank you for the info, however I hope that this workaround is only a temporarily solution right?
Yes, I hope we can find a better method to select and edit openings in the future.
