Hello
I have an urban neighborhood and I need to select all the surfaces in the same direction in one click, how this can be done in Rhino?
Thank you
Is it to (temporarily) remove or hide the surfaces? 2 ways
1- select all the wanted surfaces and put them on a layer. when selecting the layer you select them all.
2- select all the wanted surfaces and group them. when selecting one, you select them all.
Hello - So, select one surface (planar?) and find all the ones that are parallel?
SelParallelPlanes.py (1.1 KB)
To use the Python script use RunPythonScript
, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
This does not ask whether the plane normals are facing the same way, but it can easily do so.
