V5
Show Objects
I need to see what has just been revealed, nothing I immediately see but it says 6 objects reshown.
How is this done ?
Cheers
Steve
V5
Show Objects
How is this done ?
Cheers
Steve
What kind of objects do you think they are, that was shown? Do you think something in the display panel could be turned off?—-Mark
Tr sellast after you show the objects.
RM
Unfortunately that doesn’t work (at least in R5) as the Show doesn’t involve a selection.
Instead, you have to:
_SelAll
_Show
_Invert
HTH
Jeremy
Havent a clue what was hidden., not sure if their layers need to be on, …actually , if their layer was off and show revealed them does that auto turn on the layer they use ?
Jeremy, thanks, will have to be those steps then.
I also deleted all, then Show then select all and found them that way ! (remembering then to undo all that)
Steve
Sounds like you have a mystery to solve .Unless you share it with this forum or to the tech Mail. Then someone would look at it.—-Mark
Hello- ShowSelected
and HideSwap
may help.
