Hi, I’d like to see the honeybee pluggin source-code to see if there is a variable called “-b” and what is the value exposes there. Can someone help me ? i’ve tried to make this process with the python reader IDLE, but it doesnt works…
It is probably against their user license agreement to do that You may want to avoid advertising that you are trying to do such a thing.
It’s actually mostly open source and also implemented in GHPython (double click a component), see source links here (scroll down a bit):
thank you, i’ll try this method
