How to see material colors in hidden line mode in Revit?
When I import directshapes into Revit, I can only see material colors in shaded mode. How can I see material colors in hidden line mode?
Something like this? https://forums.autodesk.com/t5/revit-architecture-forum/want-to-see-colours-in-hidden-line-view/td-p/9264140
Do note there are limitations on DirectShape visibility/materials (you can’t assign a subcategory)
Is it possible to directly write Rhino colors into view filters in Revit? Otherwise, setting each one individually is very troublesome.
Certainly. Introducing Graphics Overrides in Rhino.Inside.Revit - #15 by Liam4
Can I create a legend with the set colors corresponding to the family names, similar to a schedule?
Hi Jack, I’m not sure what you are asking. Here is the Help provided by Autodesk on Legends.
via Revit API its only available with postable commands Create a new legend view - Tools - pyRevit Forums
