Is there any way we can save print setting like print color/ linetype /print width and import the setting into other file with the same layer~~~
If these settings are properties of a layer then you can save a template file with your default layers included printing properties. Then just start new projects based on that template.
You’ll have to do that the other way around - importing from another file doesn’t overwrite current file settings. So if you have a template and an existing file where the printer settings are wrong but the layer names of the objects are correct, you can copy the objects in the existing file and paste those into a new file based on the template.
Thank you ! got it!
