Hi @dale
Do you know how I save out an image from the ETO?
I have a script that makes a sunstudy, but I could not figure out how to save that to a JPG or PNG.
It’s based on stuff from here
Here’s what I do: I grab the view and alter the colors:
Hi @dale
HI @Holo, after you captured and clicked the Close button, below will ask to save as png file:
def TestSampleEtoViewCaptureDialog():
dialog = SampleEtoViewCaptureDialog();
rc = dialog.ShowModal(Rhino.UI.RhinoEtoApp.MainWindow)
if (rc):
# get the bitmap from the dialog
bitmap = dialog.Image()
if not isinstance(bitmap, Eto.Drawing.Bitmap): return
# prompt for file path
filename = rs.SaveFileName ("Save", "PNG Files (*.png)|*.png||")
if not filename: return
# save it
bitmap.Save(filename, Eto.Drawing.ImageFormat.Png)
print "Bitmap written to: {}".format(filename)
You can also run this code from a button while the dialog is open of course.
_
c.
Man, you just saved my day!!! Thanks a LOT!
I was so close… but still hours of trying to get it right didn’t get me the result, so thank you!!!
