How to save a toolbar in V9 Beta
Hi All,
I want to do a backup of my pop up toolbar before doing a reset of all the interface.
How can I do this?
I tried save RUI as and nothing happened.
BETA (9.0.26258.12303, 15/9/2026)
Similarly, how do you then import it back into V9 Beta?
The old Toolbar page in Options has nothing, and right-clicking on an existing toolbar and choosing either Edit or New leaves the Open greyed out…
@laborda it doesn’t currently work, you’ll have to go to the root of the RUI currently where Save as does work (click on All RUI files, then File > Save as)
RH-98793 Save as doesn’t work
The way to save the changes to only that toolbar is not possible, it is part of the RUI file.
There is a way to copy over a toolbar from one RUI to another:
Currently no shortcut for that in the menu but on the list now as
RH-98794 Copy /Paste a toolbar between 2 RUI files
So select the toolbar you want to copy, use Ctrl+C
Then in a new RUI file Ctrl+V
That page only holds the visual properties of toolbars
RH-98795 Make Toolbars accessible through Options > Toolbars
The current way to reset to defaults and get back a single toolbar (like the popup toolbar) back is convoluted:
  1. Run Toolbar
  2. Make a new RUI file with File > New RUI
  3. Open the toolbars of Default.RUI with the Toolbars(125) button
  4. In the Filter type Popup to find your popup toolbar
  5. Select and Ctrl+C to copy
  6. Click All RUI Files in the breadcrumb
  7. Browse to the new RUI file by clicking the button that reads Toolbars(1)
  8. Ctrl+V
  9. Click All RUI Files in the breadcrumb
  10. File > Save RUI
  11. Run Reset and reset all toolbar customizations
  12. Restart Rhino
  13. Run Toolbar
  14. Open your saved RUI file
  15. Copy the saved popup
  16. Go to Default.RUI toolbars and search for popup
  17. Delete that popup
  18. Paste the saved popup
Thanks for the feedback @laborda and @eobet I’ll get these fixes in asap :slight_smile:
Thanks @Gijs it worked, I’ll be waiting for a better solution @CallumSykes , but at least this solves thes issue.
RH-98793 is fixed in Rhino BETA
RH-98795 is fixed in Rhino BETA
