How to run this code gh.RunSolver(False) using c#?
This is code using python:
for i in range(3):
  slider.SetSliderValue(i, false)
  print "Slider value: "+str(i)
  gh.RunSolver(false)
  print "Result value: "+str(out.VolatileData[0][0])
I want apply that code into code of my, but i don’t know how to apply it in C # language
How to i run this code in C#?
[Reference]
Best regards
What is out referring to? Is that a Python specific thing, or a variable which has been assigned earlier?
I can’t code gh.RunSolver(false) using c#
In this script gh.RunSolver(false), “gh” which library to use in grasshopper?
Probably GH_Document.NewSolution(false). But you shouldn’t be triggering new solutions from within a script that runs as part of a solution, you’d end up in an infinite regress and probably a stack overflow crash after a while.
