Hi
I try paneling tool Orient 2D/3D module to grid, but they are deform. I want to keep the origin shape of model.
Detail as screencast below:
Introduction to PanelingTools Webinar.3dm (5.4 MB)
Thank
Travis
Hi
Thank
Travis
that will naturally not work, you either will have to shrink/increase the entire diameter to fit the amount of parts you need, or you shrink/increase the size of the parts till they do not distort.
that is usually also solved in an iterative process with grasshopper for instance.
maybe @rajaa can say more.
Hi Travis,
you could try _Flow with option _Rigid=_Yes:
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/flow.htm
Regards
Michael
Hi @encephalon
I watch her video. She can do it
Introduction to PanelingTools Webinar on Vimeo
watch it in 1:19:44
Travis
Hi @travis.designer.vn, I have edited the command name in the thread title to reflect the actual command under discussion.
Hi All
Any suggestion for this case?
Thank
Travis
Hi All
After watching other tutorial of Rajaa Issa. She explain that if Only click 2 direction instead of 3. They will keep model rigid.
Thank for great tutorial from Ms Rajaa Issa
Travis
