For example:
In a macro I can run: “line b”, and i will run the line function with the both sides option, in one step.
But if I have a python script and I execute it using an alias like “myline”, can I have “myline 100” where 100 is a variable used inside the script?
Hi @Bogdan_Chipara,
yes, if your python script is asking for a variable eg. a number, this number can be used as a variable. Below example asks for a length, if you enter it or pass it after your command alias, a vertical line is created at the origin with the entered or passed length:
import Rhino
import scriptcontext
def DoSomething():
'''prompt for a number and create vertical line at origin'''
# prompt for a line length
tolerance = scriptcontext.doc.ModelAbsoluteTolerance
length = rs.GetReal("LineLength", 10.0, minimum=tolerance)
if not length: return
# create a line
p0 = Rhino.Geometry.Point3d(0, 0, 0)
p1 = Rhino.Geometry.Point3d(0, 0, length)
line = Rhino.Geometry.Line(p0, p1)
# add to document
scriptcontext.doc.Objects.AddLine(line)
scriptcontext.doc.Views.Redraw()
if __name__=="__main__":
DoSomething()
_
c.
Great! I understand, thank you!
