i’ve got a script i found that is an *.cs
file, the syntax looks like rhino but i’ve never medded with c scripts before.
thank you
thank you
cs is usually C# code. You need to compile C# code into a plugin/gha or use the C# component in grasshopper.
ok, got ya, thank you
