I need to make the boundary line parallel to the edge of the page.
create a Cplane that corresponds the alignment, here i used the Set C-plane by X-Axis to create the plane.
Type in Plan to orient the view to the Plane
Create a new Named View
Change your Layout Detail Viewport to said Named View.
You can skip the NamedView aspect and do the Cplane + Plan in the detail view if you want.
