How to rotate a block on the Y axis of the Gumball , with gumball aligned to object?
I can’t find a way to rotate, with python, a block on the Y axis of the Gumball, with Gumball aligned to object.
BlockInstanceInsertPoint doesn’t return a vector…
Any advice?
Thank you
You can retrieve the Blockinstance Xform and use that to transform a worldXY plane.
From that transformed plane you can than get the Y-Axis.
pseudocode:
xform = rs.BlockInstanceXform(blockinstance)
plane = rs.WorldXYPlane()
plane.Transform(xform)
YAxis = plane.YAxis
does this help?
blockinstance = rs.SelectedObjects()
YAxis = plane.YAxis
rs.RotateObject(blockinstance,plane.Origin,180,plane.YAxis)
thank you! It works!
