Is there any way that I can reverse my zoom gesture in Rhino 6 for Mac? I’m using Wacom Intuos to model and navigate, which works perfectly in the previous Rhino 5 for Mac. I normally drag my stylus towards me whenever I want to zoom in, and the other way to zoom out. Right now it’s reversed by default.
I hope there is a setting to reverse this but I couldn’t find it. Please advise, thanks!
Strangely it worked with my trackpad, but not with my Wacom. Both the 0.9 and 1.1 have no effects with my Wacom stylus. I’m aware that not many people uses Wacom stylus in Rhino, so that could be one reason. Hopefully the McNeel team is working on this issue. I’m using the same setting/gesture with other software, so would be quite confusing if had to adjust/relearn this only for Rhino.
I barely use any of the keys on my Wacom, as I already set my own shortcuts either on keyboards or on my stylus buttons. But thanks for the advice though! I’m still hoping McNeel team would address this issue and other Rhino 6 for Mac that I’m experiencing right now.
I’m not seeing a 1.10 Zoom factor make the Wacom stylus RMB drag + Cmd reverse the Zoom direction in Rhino 5.5.4, 6.17 or 6.19 on Mac.
It does change the zoom direction for the track pad and the Wacom touch ring though. I’m not sure yet how you are seeing something different. I know from our correspondence in PM that we are on the same driver and OSX version, I was never able to reproduce any of the other issues you had though using an Intuos Pro or ancient Bamboo. For the zoom factor one, can you post images of all your Wacom settings and Rhino view preferences?
Sorry for the slow response, it’s been a super busy weeks for me with lots of traveling. I think for this one I will just let it go since I’m have adapted to the setting, so no worries. And thank you for looking into this matter, I really appreciate it.
