Hi, Newbie question. I’ve tried resizing the pipe with the scale 1D tool, but it never turns out right, it always extends it and doesn’t shorten it. Very frustrating. I need it shortened by 12.121mm. Please help! Thanks, Susan
If you type in “12.121” into the Scale1D prompt it interprets that as a scaling factor.
Try instead to set up construction points as starting and ending references:
Move the end face by the required distance with MoveFace
