Hi, I created a model that creates s hanging chain.
The points inside the curve don’t get load, so the top remains straight.
I want to create the transition from square to arch in the fixed height. I did it manually by making a chain, duplicating the line, reducing the size of the curve containing the points that will not get load, adjusting the load until the vault hits the same height, I repeat this until the rectangle becomes completely vaulty.
In the end I want to mirror the transition and create a lofted surface.
I want to know if there is a way I can create the desired outcome without creating the line one by one manually.
Here’s the grasshopper model!
CassetteVaulter.gh (10.2 KB)
