I want to make the LEFT output look like the RIGHT input (Take away the {0;30})
Any help appreciated!
In the panel menu you can disable the path and index display.
I need the output to work like it’s not got “Tree” data attached to it.
The output I need isn’t to a panel, it’s to an input.
Only the panel displays those path and index values, so if you’re using the data as an input to something else, then it’s not there to begin with. But I think I don’t understand what you really need.
It was doing some weird stuff when i was using the values to move points and then polyline between them. The flatten command seems to have fixed it.
