How to remove ShapeDiver Document Payload
2 questions:
    1. In my scene I don’t use ShapeDiver ndoes, yet I get this invisible document payload.
      When I highlight it with MetaHopper and delete it, and save the file, upon reopening it reappears. When I open the file on clients PC, it prompts to install ShapeDiver (which I don’t want to, as it is not used). Please advise. I use R8
And strangely though, when I uninstalled ShapeDiver I an attempt to create a gh file with the aforemention DocumentPayload (SDDP) node, my Python node to list all used external libraries gives error “1. Error running script: type object ‘Instances’ has no attribute ‘ComponentServer’ [9:1]” in this line:
   asm = gh.Instances.ComponentServer.FindAssemblyByObject(obj.ComponentGuid)```
as part of python node to find all dependicies
import Grasshopper as gh
if Find:
asms = {}
# Iterate through all objects in the Grasshopper document
for obj in ghenv.Component.OnPingDocument().Objects:
    if asm is not None and not asm.IsCoreLibrary:
        # Only add non-empty assembly names
        if asm.Name and asm.Version:
            asms[asm.Name] = asm.Version
# Convert the dictionary to a list of strings and remove any empty values
Dep = [f"{name} {version}" for name, version in asms.items() if name and version]
# If the list is empty, set a default message
if not Dep:
    Dep = ["No non-core assemblies found."]
You can use the “Remove payload” option from the top-level menu to solve this issue:
Ah…simple :wink:
Any idea why my python stopped working?
If you uninstalled the ShapeDiver plugin completely, I don’t think the issue has anything to do with it. If you post a definition that helps recreate the issue, maybe someone can help investigate.
