i deleted an image i had loaded with the picture command but it is still being saved a s a support file. how do i remove it?
Hello - delete the material from the Materials tab. If you have a lot of materials, filter the view (right click context menu) to only show unused materials.
Hi Pascal,
it is not a material, i used the picture command to load the image. i checked in the materials and did not find it.
Isn’t there a ‘purge bitmap’ command?
Hello - when you add a Picture in V6, you’ll get a material for it at the same time - delete this material to get rid of the texture…
Hello All:
How do I delete the pictures as support files that don’t show up in the materials log as used or unused?
I deleted everything from a file to start a new drawing – that way it saves all my dimensioning styles without having to re-input them (I’m sure there is a better way to do that!). But the new file saves all the pictures from the old file and they don’t show up in the materials log. I see them being saved as support files as the new file is being saved and now my little drawing is pretty porky.
Hilary Smith
Pacific NW
Hi Hillary - see ImportAnnotationStyles
You can use Purge
to remove unused materials.
Thank you, Pascal. I’ll certainly try both your suggestions.
Hilary
