How to remove Missing Image Files mac
I keep getting this popup for a missing image file. Unfortunately I can’t seem to find the file in the textures panel or by searching by name. How can I get rid of this popup?
Screenshot 2024-02-10 at 12.21.30 PM
Any word on this?
My guess here is you’re going to want the Purge command: check out this thread for details: How to get rid of unwanted missing images
Judging from the file path, this appears to be an image you screencaptured using the macOS built-in Screen Capture tool: command+shift+4 and then drug directly onto your model. I wonder if there is a bug here we need to address when that file was one you decided not to keep…I tried reproducing this here on my machine, but was unable to, so I suspect there’s some detail I’m missing.
Actually, I did find a way to reproduce what I think is the precursor condition for this…I’ll log it as a bug:
RH-80795 Drag and Drop Materials: Dragging directly from ScreenCapture before save is problematic
Aha, I had a a client that reported the same type of problem - 3 “screenshot images” not found - about a week ago, this explains why.
I saw a report last week of someone who was using ViewCaptureToFile in sequence to capture a bunch of images and - at some point during the process - they used macOS’s screenshot tool too and (and this part is speculation) the next time they used ViewCaptureToFile it started saving them to /var/folders/67/[...]/T/TemporaryItems/NSIRD_screencaptureui without the user noticing :grimacing:. I’ve become much more familiar with those temp folders since.
Thanks for the reply! I’ll try the purge command next time I run into this issue.
