the last upgrade of rhino 6 has a issue with “Capture viewport to file” in Display mode rendered.
I have to deliver this work tomorrow and I don’t know how to solve it.
Is it possible to recover the previous version of rhino 6?
Thanks
Thanks
This is something @DavidEranen needs to look at when he is back from vacation. If you could share a file for him at rhino3d.com/upload ( with a link to this topic in the comments section)
If you let Rhino download the updates automatically, the previous version should still be available here:
C:\ProgramData\McNeel\McNeelUpdate\DownloadCache
But please do send in a file that shows this issue and also let us know if a previous version really does solve it.
here you can download the scene and the image.
http://s000.tinyupload.com/index.php?file_id=70501927744785464553
I also upload the files in the https://www.rhino3d.com/upload
thanks a lot
bye
Thanks for reporting. I made a YouTrack item for this and will investigate: https://mcneel.myjetbrains.com/youtrack/issue/RH-47710.
I hope you managed to get a decent image created for work.
-David
Hi David,
thanx for your reply.
For my work, I have installed the previous version of rhino 6.
bye
I’ve fixed the bug but it won’t be available yet. The fix should be available in Service Release 9 which, if everything goes according to plan, should be available as a Service Release Candidate on August 28th.
-David
thanks a lot
bye
