V5,
My Picture Frame raster images (.jpg) have gone blank, just showing a white shape where once it was a photo.
How can I quickly refresh this and have Rhino show them again ?
In the middle of intensive work and the images have done this.
Select the Picture Frame, go to Properties and select the Materials tab. Find the file name under textures - color. Click on the file name to bring up the editing window. You should find the file path there: check the image file is to be found at that location and open it in Windows to check it is OK. If the file is at a different location you can click the three dots in textures - color to pick it from its new location.
Hi, this works in R5.
Basically :-
If the file is at a different location you can click the three dots in textures - color to pick it from its new location. when doing so if the file name is same and the folder that its in has a changed name, it will find the file with no need to browse, ok creates its thumb again, and it appears, with no need to scale/rotate etc whatever had been done to it in rhino.
Cause of my problem…I had shortened the folder name as a file was crashing Rhino and Pshop. and of course its caused all files to get lost.
Many Thanks, up and running again.
As for the other fix:-
drag the images into the document again. Place as Picture-Frame.
now you have both (“the”) materials twice
in properties, assign the correct material
in materials delete the damaged material
If the user has scaled and rotated an image after placement, would that method honour that or would it need such moves doing again, in which case thats impossible to know all the moves and commands that were done.
