I’ve written a program for a custom component ,there is code in breif:
protected override void SolveInstance(IGH_DataAccess DA)
Thread t=new Thread(MathCalculation);
t.Start();
private void MathCalculation()
//this program may need 30 seconds
Message="Calculation Finished!"
but when i run the component in grasshopper,after 30 seconds,the compnent can not show"Calculation Finished!" in the bottom,only if when i click the canvas or component or zoom in/out the canvas,the bottom can show “Calculation Finished!”…this is not I want,I need to
show the “Calculation Finished!” immediately without other canvas click…
Do you have some idea,Thank you very much!
It seems you are not setting the Message="..." in the main (UI) thread. I would move that line to the main thread (the SolveInstance() method, after awaiting the thread to finnish).
private void RunScript(...)
m_done = !m_done;
if (m_done)
// due to expiring the solution (far below), this will exit and
// thus prevent the solution from running the threaded code
// over and over again in an infinite loop
return;
// prepare the job to be done
var thread = new Thread(() =>
Thread.CurrentThread.IsBackground = true;
Component.Message = "Thread Is Running";
Thread.Sleep(1000); // The "job"
// Rig the component to run the "late message" in a separate
// re-run of the component
var call_later = new GH_Document.GH_ScheduleDelegate(MessageToBeSentLater);
GrasshopperDocument.ScheduleSolution(1, call_later);
thread.Start(); // run the thread
// <Custom additional code>
bool m_done = true;
private void MessageToBeSentLater(GH_Document gh)
Component.Message = "Thread Is Done"; // Now the message will come across
Component.ExpireSolution(false);
// </Custom additional code>
The Message field is just a get/set property, setting it doesn’t update the ui. You can set it whenever you want, thread doesn’t matter, but you will have to expire the attribute layout before seeing a difference. THIS must happen on the UI thread. It happens automatically if the component is recalculated though.
@RIL
Thank you Rolf
the method can work!amazing!
i see you use ExpireSolution(bool ) ,why you use bool=false?and why not use ExpirePreview(i tried,it also work…)
thank you very much again for the amazing code!
