Hi All. I have a problem to get additional nodes on the beams.
When I link the Karamba component “Line to Beam” to my line, it only recognized start and end points on that line.
I need to create a new nodes on the beam to define supports, but if I add a points on the line, the Karamba component doesn’t recognized them.
How can I do???
Any help appreciated
Hi @sonia.ruta
you need to split the lines at the points on the line before you bring it into Karamba. Otherwise Karamba will not recognise these as actual points on in the static model.
