Im trying to build a toebox using the previous 3d model. Im having trouble getting a clean smooth surface that aligns with previous model. SubD works to create a rough shape and filler but I can’t find an appropiate way to match the polysrfs perfectly. Im no good at Network Surfaces and was wondering if anyone could tell me if it would work with Crv’s I have in place, or if theres another method I should use. Hopefully the images attached show what I want to achieve.
the simple method is to quadremesh this part, convert to subd, then edit as needed. Then convert to Nurbs and proceed with your model
The more involved method would be to grab some specific software like rhino reverse, or geomagic and go through a more involved reverse engineering workflow.
if you wanted to do this all in Rhino, the process would be to extract and rebuild curves to create a clean topology layout for your shapes, then start to surface it as you would any model.
sky does a great job explaining topology in his video series here-
