How to quick open Insert-Linked file?
Hi
I use method Insert/Linked to organize Interior project. It will reduce the size of main file project.
However, I confront other problem is finding and opening the linked file.
Are there any quick tip to find and open linked file?
Thank
Travis
From the Block Manager.
Hi @jeremy5
Yes, I also find in Block Manager, however I only can read each name of file. Even if I could not sort file by name.
Are there other suggestion?
Travis
how about double-clicking the linked block?
That should initiate EditBlock, which for linked files opens them in a separate Rhino for editing.
Sorry, not at my computer: thought there was an edit option. From the command line you can use the Blockedit command.
Hi @jeremy5 and @Jarek
Great! Double Clock in block OR run Blockedit command will open new Rhino and I can edit. Then I have to close new Rhino to update. I think this is good tip.
By they way, I tried save then create new blank file, not close new Rhino. They will not update until I close Rhino.
Thank both of you
Travis
