Why the control point is not set to 0.707106781186548 by default?
Is confusing.
I wish to put it by default. Is that possible?
Thanks
Is confusing.
Thanks
What control point should be set to \sqrt{2} \over 2 , and why that value?
Dear @AlanMattano
Please give more infos / context to your question.
use
_arc
or
_circle
command to get “Expected”
in most circumstances you will not be able to build part of a circle with a
_curve Degree = 2 Curve
of course you can adapt the weight, but for anything else then 90 degree
(weight = sqrt(2)/2) you will need more math to figure out the correct weight. (assuming CV-Position is correct)
… digging… it seams quite accessible weight = sin(alpha)
https://pages.mtu.edu/~shene/COURSES/cs3621/NOTES/spline/NURBS/RB-circles.html
Hello Tom P,
I was trying to change the default curve
value from 1 to 0.707…
I do not have a clear idea of what I’m asking.
So I’m testing making a fuselage.
YES, It looks like the way to go is to use arc
semi-circle instead of the curve
command is the way to go.
Thanks for your replay
Keep in mind that poiint weights are relative - setting all to the same number is the same as all being 1 (default). Weights are useful, as far as I know, only when they vary.
