I tried to purge my model in Rhino 7. I’d like to delete all unused layers, but I don’t have simple command “purge” like in Rhino 6. Any ideas?
Hello- use the Purge
command, and set the command line options as needed. V6 is the same.
Thanks. This command doesn’t appear in my Rhino, but it worked after _Purge.
Hello- if you are not running Rhino in English, you will need an underscore at the start of English language commands.
