How to project pattern on polysurfaces rhino?
Hello - you can try this plug-in - I don’t know if it does what you need - - the biggest limitation is that the target object must be larger than the bounding box of the objects you are projecting. See the example file. Un-block the plug-in in Windows and drag and drop onto Rhino to add
ProjectObjects
ProjectObjects.rhp (20.5 KB)
ProjectObjectsTester.3dm (1.4 MB)
