Project multiple buildings on surface.gh (25.4 KB)
Hello!
I am trying to project multiple Breps (buildings) on a surface (slope). In the script I made the Brep moves to the lowest point where it intersects with the slope. It works when I set 1 Brep as the input but not when I set multiple Breps.
Can someone help me out! I have tried to graft and simplify here and there but it did not work yet.
Thanks.
Thanks for helping, very clear script! But I would need not the closest point between curves but the furthest. Could you adjust the script?
Thanks for the help! As i understand the ‘box corners’ component is making a bounding box. Because the slope that i will eventually use it for is quite detailed i am afraid that the bounding box is not as precise as I want it too. It works good though! But do you think it could be a bit more accurate?
The previous definition took into consideration only the edges while this one evaluates the entire base surface.
Project multiple buildings on surface c.gh (44.2 KB)
The difference between my two definitions.
