Hi Sir:
I would like to project mesh boundary on the system plane.
my process is
- Dulboarder to get boundary.
- select boundary to project “on a plane”.
“on the plane” means the base should be a plane.
My question is how to build a vertical mesh wall?
Hi Sir:
my process is
Hi Frank - try this: DupBorder then ProjectToCPlane > DeleteInput=No then Loft' the two curves with the seam point adjustment set to 'Natural' and 'Do not simplify' in the dialog.Meshthe result.Join` the mesh to the orginal mesh.
